Hi
Happy new year to you all.
Ive just had a sort out of my stores.
Please see below a list of electrical items for sale.
Will sell individually or the whole lot or combination of items. Collection from Dartford area or will be willing to post if you are prepared to pay for postage.
Any questions please feel free to message me.
ITEMS
flush metal back boxes 47mm double pack of 5 x 6
Flush METAL back boxes 47mm single pack of 10 x7
BG MCBs
B50 x3
B40 x9
B32 x10
BG main switch 100amp x2
Contactum MCB s
B40 x1
B32 x2
B10 x1
MEM MCBs
B32 x3
B16 x3
B6 x3
Schneider MCBs
B10 x1
B6 x1
M2 MCBs
B32 x2
PROTEUS MAIN SWITCH 100amp x2
Hager MCBs
B50 x1
B40 x1
B32 x1
B16 x4
B6 x2
Hager main switch 100amp x2
MK ( older type MCBs)
B32 x6
B16 x1
B6 x3
CED MCBs
B20 x2
B16 x2
CED MAIN SWITCH 100AMP x1
CED RCD MAIN SWITCH 80AMP 30mA x1
Crabtree loadstar
Mcbs
B32 x2
B20 x1
B6 x1
Rcbo C6 x3
Crabtree starbreaker.
MCB
B16 x1
B10 x1
RCCB MAIN SWITCH (2 module) 80amp
30mA x2
RCCB MAIN SWITCH (3 module) 80 amp 30mA x1
Main SWITCH 100 x2
Consumer unti RCBO B6 x4
Wylex convertor MCBs
B40 x2
B32 x9
B16 x1
B10 x1
B6 x4
MANROSE 4INCH 100mm low voltage fan and transformer 85m3 per hour 12volts IP24
MANROSE CENTRIFUGAL EXTRACTOR FAN .
4INCH 100mm CF200S STANDARD MODEL.
110m3 per hour
6inch pendants x6
12 watt IP56 round LED bulkhead x1
12v 30dc LED power supply IP 67
12v 2.5amp 30watt constant voltage x3
Box of earth clamps x1
Schneider 2gang light switch white plastic round edge x7
BG 45 amp d.p. ceiling pull cord switch with neon x8
BG NEXUS WHITE PLASTIC round edge:
45amp DP switch ( single plate) with LED x10
45amp DP switch ( double plate) with LED x8
Unswitched spur x10
4gang light switch x9
3gang light switch x7
2gang light switch x10
1gang intermediate light switch x7
BG NEXUS GRID DIMMER MODULE 2way 400 watt push brushed steel x4
1gang light switch basic white plastic x8
BG NEXUS METAL BRUSHED STEEL :
Single socket x4
UNSWITCHED spur x8
3gang 2way light switch x3
2gang 2way light switch x6
Shaver socket dual voltage x2
BG 1gang retractive press switch x5
Contractor plus 3gang light switch 2way polished chrome with black inserts x1
One electrical super slim 1gang 2way brushed chrome black insert surround screwless x2
BOSS THERM TIMESWITCH BUT2 X1
MAJOR TECH MT 770 AC CLAMP METER x1
If you need any further information please feel free to get in contact.
Manythanks Darren the electrician from volt-elect
That’s the stock check of every electricians shed!
Yes, unfortunately most of us have a collection of new MCBs left over from buying populated consumer units, since it often is cheaper this way. I regularly throw away new BG and MK MCBs, I can't give them away.
Dartford
Business Name
Volt-Elect Ltd
Electrical accessories for following stores sort out
For Sale and Wanted Forum
Darren Cox,
SJD,
