Discuss Electrical shower confusion in the UK Electrical Forum area at ElectriciansForums.net
Hey guys,
I'm currently doing my level 3 install qualification and I've been asked by someone to replace an electrical shower unit for them, now from my knowledge I am allowed to do said work as long as the power rating of the shower is the same as the old one and that it doesn't need a new rcd or wiring. However it is illegal to do electrical work in a wet room without having the correct qualifications and competency. Can anyone clear this up for me please as I'm confused
You’re probably thinking about Part P, where you have to notify the LABC about work within the zones.
There’s no law saying you have to be qualified to do electrical work.
As far as I am aware, maintenance whether it’s in the zones or not, does not require notification.
Hi,the above is all good...the only thing i would add,is like-for-like,is OK,as long as original install was correct.
Swapping a 7.5kW for another 7.5kW,is fine,until it is discovered,the first had a 2.5t&e feed.....:)
(The above offer,is not intended as a slur/jibe/pedant...all other opinions apply...taken from real world example....normal T's and C's apply......;))
I would just add, replacing a faulty shower unit with another, maintenance wise, without the manufactures instructions of RCD protection (which only has to be taken into account), is not worth putting your arse on the line, so to speak.
Reply to Electrical shower confusion in the UK Electrical Forum area at ElectriciansForums.net
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Hi all, The PRD went on my Triton electric shower. I opened it up to find out where a replacement would go, and someone mentioned that the wiring...
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
