Lighting is by candle only as the cable has gone the same way as the lead & copper pipe, the pool table has been ruined by the rain leaking through the roof and the snow blowing through the broken windows.
I've robbed the slate for my wood burner hearth.
All the posts tonight on how we are so abrusive to people and now you want to join arms......get ready..... once your key is cut....the gloves are off.....!!!!!
I've started stealing pallets for fuel for me burner, seeing as the gas is so frigging expensive and Our Lass won't let me bypass the meter.
A good hefty pallet gives a good 8+ hours of heat, so I'm in wood credit at the moment. :-)
I've got piles of wood all over the place now!
Having bad problems with Pallets and coal at the moment....south wind blowing so back draft down chimney....co detector going mad so if i dont answer a post within the next 20 mintutes be a darlin and phone 999
It takes considerably more than 2 pints of Rooster's IPA and 3 big bottles of Beck's to gert mee starlking a bit....
I'm on a temporary setup at the moment.
Stove on concrete slab, black enamel pipe to SS flue liner, which is just poking out through a hole in my roof.
The liner is rigid enough it doesn't need any support over the tiles.
Thing draws like a dream, zero back draft.
Well need to take a leaf out of your book, things bad in Surrey if we get down draft it means snow......but time i fitted a sealed woodburner me thinks...
