1Justin
Wiring ELV (24V max ELV 2 wire) boiler 'stat. Hidden cable. - Would you be too bothered if you needed to break "zones"?
(*Where it also makes it easier to provide segregation from Band 2, and otherwise would cost a lot more and put the Customer off?)
abplease explain better. if the cable is vertical or horizontal run from the stat, it's within zones.
.. It might not be.. For instance décor preservation may encourage me to run it concealed on the other side (and the wall is >100 thick so that is outside zone).
as it's elv, then there's no danger from shock. as long as a diagram is left with the client, then i'd go ahead.
