R
robbieh
any body finding that emergency lighting tubes are lasting about 3-4 months having the tubes
go out on 3 different jobs 3 different makes of fitting the normal fittings fine but the em,s
short lasting ?
if they are switchable maintained fittings and are on in business hours then you've used up the lamp life approx 5000hrs ... more info, nd is the customer asking you to replace them under waranty if so you havent done your sums and should have informed them of the lamp duty, hence pying the extra for led fitting would have saved money
robbieh,
robbieh,
