Discuss EPO connections in the Canada area at ElectriciansForums.net
J
jonny1
Would someone go to the trouble and explain the connections for an EPO at the distribution board pls. Its a 3-phase 160A
Then it's simple. Just install a 160amp contactor between feed to the board. The coil feed fed from the board, line out through n/c stop button/s. The N direct on other side of coil.
The coil will re-energise if the stop button is released.
If you require reset facility then its a bit more involved.
You would probably need to fit an isolator prior to the contactor also (assuming there isn't one already.)
Sometimes it is advisable for lighting to be fed separate, thus hitting the es will not cut lighting
Reply to EPO connections in the Canada area at ElectriciansForums.net
We are looking for a distribution board to provide 3 * 160A three-phase feeds, but they are basically redundant supply path options so max total...
We have been provided with an Eaton NZM-1 160A 3P MCCB in a panel for a distribution circuit on a site but was hoping to find technical data sheet...
Hi, just looking for advice. Ive been to look at a Fire alarm install job. While checking where i will take my supply from. 3 phase sub board, i...
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
When there exists a single-phase transfer switch within a 3-phase distribution system, is it necessary for both feeds to the transfer switch to be...
