Discuss Escalator Power in the Canada area at ElectriciansForums.net
N
nancy
I'm having difficulty researching information on how an escalator is powered. I understand that it uses a 19kW motor and there is a three phase supply, but don't understand how this all works together. Can anyone shed some light?
Well it's a bit topsy turvey, basically you need to stand on this steel like stuff. (depending which way you want to go will determine which direction you opt for)
If the magical stairway is heading down, and you wish to go 'down' stand on the top tread then you should go down (check before you stand on the magical steel)
If you want to go up, the reverse procedure needs attaining. Some times 3-phase is complicated, because there is normally only 2 choices, up or down, the extra phase is now popular for straight-on, airport walkways etc. But this new technology is getting far too complicated for most people -;)
I want to know how an escalator is powered. What does the three phase supply mean and the 19kW motor - is that an AC motor? Not sure were to get this technical info from. I know how an escalator works - chain loops, gears, truss etc; just nothing to do with the above.
Before anyone could answer your questions then they would have to know your level of knowledge of electrical theory in order to know how in depth their reply may be
You have been given an answer, that they go up and they go down
If you require further insight into the ins and outs then,understanding three phase and single phase electrical theory should be your first project if you are to progress
Reply to Escalator Power in the Canada area at ElectriciansForums.net
We have a 5.5kW incoming supply, which cannot practicably be upgraded due to our remote location in the mountains. Can I use a PV array and...
Hello right off the bat I'm a novice with a little better understanding than most(father was a electrician) but I am not an electrician. I'm...
Hi all, Curious one and hopefully some one of you could give me some advice. A customer has had a steeltech shed installed at their premises. A...
Hello, I would liked to install a Byron wired doorbell with built in chime and 8v transformer. I'm struggling to get power source. I have a...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
