Discuss EV installer around Liverpool in the Electric Vehicles Advice Forum area at ElectriciansForums.net
I’m currently looking to get an EV Charger installed at home if anyone is able to or could recommend someone that would be great.
Cant point you in direction of anybody that far north but what charger you after? I would be looking at either The Hyypervolt or Zappi.
I fit upwards of a dozen each month so happy to answer any questions on this or other chargers...
Likewise if you sent me a load of photos of what you have I can tell you any pitfalls or problems. Also explain the grant process.
Main thing is the cutout - do you know fuse rating in the carrier? Do you have a looped supply?
Nothing to stop you doing the dno notification now as if work is required it can take weeks if not months and with xmas coming things will go slow.
Regardless of charger you go for you can do a lot of this yourself... Running cable plus cat5e or use ev ultra as the hypervolt really should have the ct wired for full functionality.
Artisan Electrics' Corey did a recent vid on what thry look at when doing a site survey for EV, might be worth a watch. Aside from certification for a new circuit, any reason for not doing it yourself?
Reply to EV installer around Liverpool in the Electric Vehicles Advice Forum area at ElectriciansForums.net
I have a client who wants an EV charger installed, charger TBC, but about 7KW, installed about 20m away from this installation. I've not done one...
I’m wondering if anyone would be able to tell me if I have a looped supply in my property as I’m looking to install an EV charger.
I am an NICEIC contractor but I have never installed an Electric vehicle charger. I have watched all of the relevant NICEIC webinars (The wire) on...
Hi I'm just starting to fit EV chargers as part of our solar installs. Just looking at the tester options I currently have a Megger 1711 but this...
On another forum for general EV chat this question comes up all the time. It's very common to install a charger taking the supply direct from the...
