I’m currently looking to get an EV Charger installed at home if anyone is able to or could recommend someone that would be great.
Cant point you in direction of anybody that far north but what charger you after? I would be looking at either The Hyypervolt or Zappi.
I fit upwards of a dozen each month so happy to answer any questions on this or other chargers...
Likewise if you sent me a load of photos of what you have I can tell you any pitfalls or problems. Also explain the grant process.
Main thing is the cutout - do you know fuse rating in the carrier? Do you have a looped supply?
Nothing to stop you doing the dno notification now as if work is required it can take weeks if not months and with xmas coming things will go slow.
Regardless of charger you go for you can do a lot of this yourself... Running cable plus cat5e or use ev ultra as the hypervolt really should have the ct wired for full functionality.
Artisan Electrics' Corey did a recent vid on what thry look at when doing a site survey for EV, might be worth a watch. Aside from certification for a new circuit, any reason for not doing it yourself?
RDB85
Trainee
Liverpool
Trainee Electrician
EV installer around Liverpool
Electric Vehicles Advice Forum
Thread Tags
RDB85,
Lister1987,
