Hello,
A property has 2 gas meters (flats).
One is already bonded. Plan is to jump of this bond to get to the second meter. I know the cable has to be continuous.
What kind of join would you recommend?
I was thinking to use the current cable (currently from cu to meter 1) and go into a MET bar which id install inside the property but not next to the consumer unit. This met would be boxed in. From the met ill install 2 singles, 1 going to meter 1 and the other carrying on to meter 2? Good idea or can a alternative be recommended?
