B
BillyH
Is permissable to extend the earth conductor in t/e by soldering? I have a job where all the earths in a small extension have been cut off (lighting only) . Not really enough cable to get a through crimp on and rewire is out of the question.
can't see a problem with that as long as the joints are good and sleeved. but are the fittings classII?
Any chance you can get a push fit connector on? I'd be concerned about heat transfer if there's not a lot of conductor showing.
If the soldering is to be carried out in such a restricted area you may find that you will damage the cable insulation
My God it must be tight to have to resort to that, how about a wago or is that not a possibility?
Fittings are all metal. I have just rewired the lights thought the house due to no earth conductor so I assume the div that did the extension assumed he would carry on the no earth theme
