Discuss Fairly making money by sub-contracting - New Business Startup in the UK Electrical Forum area at ElectriciansForums.net
Why bother having the customer set a budget then, as if that's magically going to make the spark do the job at a cheaper price, if as you've admitted the quote could come back over or under budget. The second most important thing I think is being overlooked is most sparks won't quote, they'll only estimate. So what happens if the subby estimates within budget, but finds half way through the job that it's going to cost another £1000 because something unexpected came up?
I think you've created in your mind a simple solution for a problem that is anything but simple.
True. Do you have an experience you'd like to share? Have you ever told a customer "hey James, I need to replace x because it's out dated so it will cost an extra x"?
This is why I take onboard your feedback strongly so I know and think this properly.
I'm a trainee, but I've worked with sparks that have had to - it comes up quite frequently in electrics, your tests can only prove so much but when you start scratching the surface a different story starts to appear.
Please can you elaborate on this. There will be more than one budget range? So in your example there will be a 2k to 3k, then maybe a 3k to 4k then maybe a 4k to 5k.....??
Why would the customer pick the 4k to 5k when he can get it done for 2k to 3k? What is the difference?
or am I just reading this wrong....
Yes. Different budgets. So if the customer selects 1k - 2k and need a rewire (their description) then that's a no no. We would alert the customer that an acceptable budget for what they want is x. This website will be "smart" based on your description you fill in.
All that will happen is that your rakeoff will be added to the quote, so it'll be that much more expensive than quotes gained not via you - you might see a dribble to work through your books, but you won't live off it. Youve assumed the customer will get all of the quotes for the job via you - that's just not going to happen.
Your business model is flawed, you do nothing to justify such a high % takeoff - all of your competitors are doing is encouraging a race to the bottom in terms of cost and quality - the customer suffers.
Youd be far more likely to earn a living, and encourage trades to sign up with a sub 5% rakeoff, if you could target your market at the high end where customers don't mind paying a bit more for a top quality job.
All you are trying to do now is to reinvent a broken wheel.
Can you also explain how the quote system works as I all it can ever do I give a very very rough ballpark figure.
e.g. say I want a cooker point adding. How will it quote for this? It could bust be a simple cable going from consumer unit, then under the floor to the new cooker point. Or the floor is solid so has to go a different route. or the customer wants the cooker point fitted to an island in her newly tiled floor kitchen.
It's a smart app remember, runs on smart phone so uses GPS to work out routes lengths, ground penetrating radar module plugs into headphone socket to determine structure construction. Also does post code lookup to calculate your travel costs (and the chances of you getting your van nicked), and plots route to nearest cafe.
haha now that what I call a good idea..
Our percentage takings are not finalised, it's just a placeholder value to work with. We will see what expense we accumulate running the website and app etc.
Just to shed some light, 15% will be very high, I agree but I just used that for now.
I have not mentioned this part:
Research is needed to know what these sort of services costs. I wont offer "light buld replacement services" but rather re-wire services: services with high value. So a market research will be conducted to see what each services cost and things to expect then based on that, we based the selectable budget. Customer will select a dropdown of services and based on that a budget to choose from.
I agree with many of the comments above. Letting the customer set the budget for the job is definitely the wrong way to go. I'll give an analogy: Person A has £200 budget to buy a TV. Trader 1 offers them a 32 inch HD LED Samsung with a 2 year warrantee, trader 2 offers them a 4k 50 inch TV, but its unbranded and the trader won't say where is from, or where they are from, etc. Most people would not be stupid enough to buy from trader 2. It's not like that with electrical work. Most people don't know their a##e from their elbow electrically speaking so more for less is an attractive option and so customers will set the lowest budget your site will let them. And you'll be able to find "electricians" who'll work to the budgets set, but unlike rated people who manage to distance themselves if your subcontracting cowboys you'll get the flack. And if you get good tradesmen and you're constantly telling customers their budget isn't high enough you'll not keep many of them. Time for a rethink methinks...
...Most people don't know their a##e from their elbow electrically speaking so more for less is an attractive option and so customers will set the lowest budget your site will let them. And you'll be able to find "electricians" who'll work to the budgets set, but unlike rated people who manage to distance themselves if your subcontracting cowboys you'll get the flack. And if you get good tradesmen and you're constantly telling customers their budget isn't high enough you'll not keep many of them. Time for a rethink methinks...
You have not got the concept, I have noted this in previous comments. They will select a budget (based on feedback we set values):
Title: Select work type:
{customer chooses full rewire}
Budget:
{customer selects "£2K - £3K"}
Description:
{Customer: I have a one bedroom flat etc}
The customer could also say "I have a 2 bedroom flat etc..." so based on their description we would determine the correct budget. If they selects the lowest budget and their description has "I have 2 bedroom etc..." we would contact the customer explaining to them x and y.
Reply to Fairly making money by sub-contracting - New Business Startup in the UK Electrical Forum area at ElectriciansForums.net
An Invitation to Retired Electricians anywhere except the UK with Four Days a Month for a Niche Opportunity That Can Earn 15K a Year. There are...
I'm delighted to announce that some time in the next few days / weeks, BBC Breakfast will be airing a short piece about MEET (The Museum of...
5K
Renewable energy startup is seeking a Technical Co-Founder to help create a company that is both socially and financially rewarding. The...
  • Locked
5K
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
