J
Just
Good evening, I am about to purchase a new SDS drill but today I was fitting an extractor and could have really done with a core drill. A few questions if I may.. Do you think this is man enough as it would be nice to have an allrounder instead of a dedicated core drill? Can anyone better this deal by price or a better drill?
HR2470:MAKITA-MAKITA HR2470 SDS Plus Rotary Hammer Drill
If I need a core saw once a month, can someone recommend a fair quality nicely priced core saw that'll do the job and not break the bank? Should I go for a 110mm for a fan cutout or 105mm if available?
Thanks for the advice.
You need a machine with a clutch if you are to avoid breaking bits of yourself. If a large core bit jams it can break your wrist or throw you across the room or off the ladder
I use one of these for diamond cores
8406:MAKITA-MAKITA 8406 13mm Diamond Core Drill* 850W
And have a large rotary demolition hammer for TCT cores
With regard to size 110mm or 117mm are the best size
For your needs it may be cheaper to hire
i use a aeg core drill which is very good as for diamond core bits i use 117mm screwfix do a good deal in the erbauer range iv cored out 4 fans with mine and theres teeth on bit still:D
I have the Makita, the same as UNG's.
I use the Clarke diamond cores from Machine Mart with it...very happy with them.
Just,
Guest123,
