I would either as stated fit another small cu or lift all flooring and use a multi tool on the flooring in the attick if full house rewire was required. And get your circular saw out to cut the boards near the fitted wardrobe and feed under if required.
you either get the go ahead for full rewire and charge for it or they go cheaper and sub unit splitting the tails.
just my opinion.
No, i was thinking along the lines of grabbing the supply up to the loft, at upstairs floor level. Just as easy to use the downstairs lighting circuit, ...3 or 4 extra points isn't going make much of a difference to the circuit make-up, especially if were talking LED lamps and fittings!!
Anyway, There always seems to me to be excuses put up, as to why they can't possibly use existing circuits for any extension work, it always has to be a sub-main CU.
Id be trying to use existing circuits where possible. Id even consider FCU on ring for an extension thats attached to existing building.
Thinking about it now, I only really do submains for outbuildings that are far away from existing house. Ie buried armoureds etc where meter is external to house.
I didnt consider finding supply on way to the loft. :)
If there are only lighting points in the new extension; are there any existing outside lights you can use to get a feed?
Theres too many options to consider without looking at the job.
The only place I really draw a line at not getting flooring up is in a bathroom. Tiles or lino. And I wont remove sanitary ware :)
just my opinion.
Who mentioned complete re-wire?? Were talking about providing for a few lights and some extra sockets in a couple of small rooms and a passageway!!!
It's understandable having separately located CU's in very large houses and premises, but are rarely justified in your typically sized 2 to 4 bedroom houses!!
I don't know, ...dodgy fitted wardrobes (if fitted over carpet), dodgy loft conversion and now a possible dodgy electrical installation, not having much luck your mate!! lol!!
So what's the problem with lifting the new carpet and floorboards then?? No idea why you would need to get into the loft??
still not as bad as this painter & decorator i used to know called lee..
lee got a job on a place whilst the owners were on holiday...he wallpapered around a wardrobe rather than shift it...
he also invited his bird over to the house he was working at and they got jiggy in the bedroom....then the owners had come back caus they forgot something and caught them both shagin....
does seem a bit ott pulling in new sub main. cant you pick a under used and close by socket, fcu...couple sockets...another fcu, the couple of lights. failing that, extend ring, or indeed instead of sub have a radial. just throwing out ideas with a tinny
