Ive got the bosch, great bit of kit, downside is blades wear out very quickly and are EXPENSIVE to replace, ive been keeping an eye out for suitable alternatives but no luck as yet. I dont use it every day but sometimes its worth its weight in gold :-D
Hi Mark, the Fein Multimaster is a great bit of kit, wouldn't be without mine. For cheaper, but quality, blades for the Fein (and other makes) check out these guys:- Shark Blades
check to see what Mk fein you have. We have the Mk2 on the van. We bought a set of Faithless blades that claimed to fit the fein, but on closer inspection they only fitted the Mk1, not the Mk2! Obviously changed the design of the head to only accept their own blades I would imagine!
Someone needs to tell Shark that the point of multi-buy is to save money....
1 X 65mm Standard Blade £6.50
3 X 65mm Standard Blade £19.95 :mad2:
The other multiples seem to make sense though.
i have the bosch 10.8 professional and its one of them bits of kit you might not use everyday but when you do it was worth every penny, mine was £199 including delivery and 36 blades sanding sheets etc and a drill, :-) it was £183 for the tool with accessories so for the extra £16 i thought why not lol
One of those bits of kit that you never knew you wanted until you saw someone else using one!!!! I love my bosch one.
I'm looking at one of these is the top plus kit the best VFM £240 delivered is about the best price i've seen)? Also has anyone tried the 18v Supercut, expensive but bloody hell what a mighty looking tool
