25mm2 are fine everywhere except the lounge, I tend to stick 35mm2 in as standard in case the customer decides on a dimmer
This seemed a bit over-speced at first, but after your comment about the customer deciding on a dimmer, it all made sense.
Would you use a 125x3 cee-form on the end of your 35mm2 cable in the lounge, or do you tend to use Camlocks? ;-)
