Discuss Fitting lights in the UK Electrical Forum area at ElectriciansForums.net
I have some light fittings to put up in a kitchen replacing the existing fluorescent lights. The new fittings are 3 light ceiling spotlights that come with a centre bracket the fitting fixes to and sits flush to the ceiling. The issue I have is that it is an old cottage with open beam ceilings and the exposed floor boards from the rooms above. Fixing to the floorboards means there is nowhere to take the cable into the fitting. Any ideas how to do this without butchering the fitting would be helpful. I have attached a picture of a similar fitting to see. Cheers
you need to cut a cable entry into the firring, or dig into the timber,
I thought about cutting a cable entry into the fitting just need to make sure it looks ok. With the fitting being metal would have to have to protect the entry hole with some grommet strip or similar.
"The Mahogany pattresses are made from MDF, with a Cedar veneer and Mahogany stain, and laquered for a smooth and durable finish. "
So, not exactly mahogany, then...
Could you post a pic of the ceiling/beams/floorboards? I carried out a similar-sounding job recently on a pergola on an outside terrace.
MDF ... ach.spit. you need real mahogany or oak. pirate will tell you that it's good for outdoors, impervious to salt water, good for keelhauling the revenue men.
Reply to Fitting lights in the UK Electrical Forum area at ElectriciansForums.net
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
Just had a simple kitchen light not working job, one of the fittings with the 4 spotlights on it. Took the fitting down to check if there was...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Hi Family member has moved into this house which is about 110 years old. Bodges everywhere inc the electrics. We are just rennovating it and when...
R
I am looking into LED lighting for a Grade I listed church, parts of which are 800 years old. The lighting must be simply dimmable with a colour...
