Discuss Fitting tracker to vehicle. in the Auto Electrician Forum area at ElectriciansForums.net
This demonstrates how shallow your knowledge is of vehicles using this technology, until you manually stop the engine it remains active
So you’re telling me that if I connect the relay in front of the starter motor, someone steals it and the tracker notifies me, I press the button to throw the relay cutting power to the start motor, the engine won’t cut out immediately (because that’s illegal) but the next time they stop the car and the engine stops with it, the starter motor isn’t used to restart the engine? Is that what you’re saying? The starter motor is ONLY used when you first push the button to start the engine?
I don’t know what “remains active” is supposed to mean, or what effect it would have.
What I do know, is you need to tone it down.
The OP has asked for advice.
If you don’t want to give any, then don’t.
There’s no need to be insulting.
Thank you spinlondon. I get fed up with these forums sometimes. Every forum has people like this. Don’t actually want to help anyone, just ridicule them.
Sounds like you have jumped into a thread without reading through it
I think from some of your replies in other threads you need to take some of your own advice
The stop start system once the engine is started is operated from the ECU not the button on the dash until the button is pressed to stop the engine and it is then deactivated
You are making an assumption the the start button has a direct connection to the starter motor this is not a latching button
Clearly the advice I've offered does not meet your expectations or has been misinterpreted, I don't know your level of competence or what tooling and test equipment you have available to you, what I do know is they are complex vehicles that need a different approach to the one your have.
If you are considering continuing with this mod and "brick the vehicle" it will turn a cheap mod into a very expensive *****
Trying to run a modern Land Rover on a shoestring budget isn't an easy thing to do and most of the people I know doing it have access to at least their own diagnostic equipment
On that note I have taken your advice, you have been assigned to room 101 along with another contributor to this thread
Ironically I think our ‘wires have been crossed’ (don’t trip over that pun)
I was talking about if I was going to put it in front of the starter motor as obviously the starter motor will turn every time. Yes I agree that the button won’t have the same effect.
Other than the belittling yes your contributions have been some what helpful. I know these are complex machines but what I am looking to do is not. I don’t intend to intercept a data line. From my understanding of it is that when you push the button it sends an electrical signal to the computer telling it to start. If I close the relay it was stop that signal from being able to get to the computer. Which is exactly the same as just not pushing the button. I can’t understand how this is so complex and would damage anything. It’s either sending pulse voltage or not.
I’m not saying you’re wrong, but fitting it this way, can you explain how this could be damaging to anything and what could go wrong? (Assuming I’ve metered and found the right cable) I can’t see that putting a closed relay is any different to not pushing the button.
With the relay closed if a thief pressed the button that signal would simply just not reach the computer, same as before he pressed the button. No?
A problem with that scenario, is you don’t know what the stop?start button does.
It may well be that the button just sends a signal to the ECU, and the ECU then decides what action to take.
If the engine is not running, the ECU starts the engine.
If the engine is running, the ECU stops the engine.
Disabling the start/stop button may mean the ECU never decides to stop the engine.
Amazing!! Exactly what I wanted from a reply post. (not what I wanted to hear but none the less, thank you) Informative and pointed out something I weren't thinking of. Thank you.
Yes you are right. It is a dual purpose button so there will be some coding deciding what to do when it's pushed such as an if/and/or formula and so you're spot on, severing the link will mean it also won't turn off.
So the start/stop button is a no go.
I admire your tenacity. At the end of the day it's up to you what you decide to do, but I think you know in your own mind there is an element of risk to say the least.
Well I’ve just had a look and there is no way of getting beneath the fuse box which is where I thought would be the best and easiest way to identify the right wire to put it. So don’t think starter motor is a go.
it's made by land rover, if it gets nicked, it won't get far before it dies. check AA and RAC websites.
Reply to Fitting tracker to vehicle. in the Auto Electrician Forum area at ElectriciansForums.net
