Dartlec
Given that the cable isn't broken the important thing is to protect it from touching and shorting if it may still be live. You seem to have managed that temporarily, but will need something more pemanent before the carpet goes down.Thank you for your replies and advice. I'll take a look at the earth tomorrow. The cable isn't quite as chunky as another bit of 6mm I've got in the house but it's a a lot bigger than the 2.5mm. The cable itself didn't give any indication as to the size, it just says "Volex Salford".
I've got an electrician coming soon to wire the cooker/hob cables into the fuse board but that won't be for a couple of weeks. I was hoping this would be a quick and straightforward job I could do myself before then so I could get the floorboards fixed in place and carpets laid but I can wait for him to check it out if needs be.
I wonder whether If it could be put into one of the old circular junction boxes, then that may be enough - the point of a maintenance free junction box is that the terminals can't come loose - but in this case there are no 'terminations' as the cable is still complete. The point is to safely insulate the cable.
But if the electrician will be working then he will be signing things off so it should probably be his decision. It might be a case of asking the electrician to pop in earlier, even if briefly - it shouldn't be a long job.
