Discuss flexi cable in the UK Electrical Forum area at ElectriciansForums.net
It's called tri-rated. This is because it conforms to 3 different national standards (uk, US and Canada I think).
It is to BS6231. It can be ran upto 90deg Celcius, but design to 70 as the MCBs ect are unlikely to be rated any higher.
You should be able to get it in most wholesalers
Reply to flexi cable in the UK Electrical Forum area at ElectriciansForums.net
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
Hi! I have a led strip (12V) with an external cable (2*1mm) glued on the wall and it's not fancy at all.. Inside the wall I have 3*1,5mm cable...
