Discuss Floor boxes on raised access floor in the Australia area at ElectriciansForums.net
sparks1234
What options are there for wiring 3-compartment floor boxes in a raised access floor? obviously the best job is usually going to be in an electrak type system....problem....expense, the busbar is not exactly cheap and the tap offs are over twenty quid each.
Another option is trunking and flexible conduit, but what regulations apply to using twin and earth fixed to the pedestals? or laid on cable tray....over to you
Theres nothing against you cable tieing it to the pedestals, unless someone can tell me a reg it contravenes??
I would say this is the most common method I come across
Ta:D
The only floor boxes i have been involved with were in a 2ft x 2ft square modular suspended floor with the boxes cut into the square where needed.
All cables run in kopex.
To be honest, if its a new install, then there isnt really any other way than using the trak.
Reply to Floor boxes on raised access floor in the Australia area at ElectriciansForums.net
  • Locked
5K
Just carried out an EICR on a flat that was wired in the 70s - with singles run in earthed conduit to each point and the trunking providing the...
4K
So I have had an enquiry about a large open plan call center with around 150 desks. Rented office space, each desk has at least 1 pc with 2...
4K
Hello, Whilst doing some building works I have access to the inside of the stud wall to which the consumer unit is fitted, so full and easy...
4K
