Discuss Fuse size for 12v hydraulic diverter valve in the Auto Electrician Forum area at ElectriciansForums.net
Hi
I’m about to wire up a hydraulic diverter valve to add a 3rd function in my 60hp tractor front end loader.
I will draw power from my ignition but I’m wondering what size fuse I need to run?
looking at pic#1, it says 30W which is 2.5A, so a 5A or a 7.5A fuse would seem appropriate.
Reply to Fuse size for 12v hydraulic diverter valve in the Auto Electrician Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi, I have very little electrical experience and would like a bit of advice. I have a kerosene pump installed in the back of my van. According to...
Hi I’m stumped and can usually figure it out after a while but not on this one. so I joined here In search of some help on my 05 tundra I’m...
Hi, I know it's best practice to run an immersion on a dedicated circuit but am I OK with the following A new heat pump is being fitted and it...
Hi All, I'm looking at installing an induction hob in my kitchen (upgrade from gas) and I gather that it can be added to the cooker circuit if...
