Discuss Fusebox consumers units in the UK Electrical Forum area at ElectriciansForums.net
TJC1
Has anyone used the brand Fusebox before, how do people rate it as I’m just looking at there main switch spd board with RCBOs
We always use Hager! But just shopping around...
Yes, I've installed several of the all-RCBO boards including the SPD, from the 6 way to the 20 way versions.
One of the main criteria was a reasonable cost RCBO, and no trailing earth leads from the RCBOs to make the board look like a bowl of spaghetti.
Another vote for Fusebox here, used quite a few of them in past 4 to 5 months, decent quality overall, and the price is extremely keen compared to Hager, like how the SPD comes with its own wires or connected in some boards. Whereas any others I've used you need to add your own wiring to connect them.
Just seen them for the first time here in century electrical this morning as its somewhere I dont usually go. Would you say it's worth giving them a go then?
DSS electrical on the tube is now saying they are the worst boards he's ever fitted. Worse than BG - that takes some beating!
Have to say I've been looking at them though given the price. Been given good prices by YESSS
Have you a link to the video?
I have fitted loads of BG before and would personally rate the Fusebox a shed load better than BG, I really can't justify paying double the price for an Rcbo and SPD just because it says Hager on it. I'd rather have the price difference in my bank account than Hagers lol
@Phil Thompson its here:
View: https://www.youtube.com/watch?v=v5QOQ2XOqbg
start of the video. The slagging off starts around 2 minutes 15
I wouldn't listen to that guys comments, no facts or reasons given, just a throwaway comment that they are poo, without justifying it with any issues he found.
Quite often when I've heard other sparks complain about certain materials it's down to themselves and not the actual item they are complaining about.
The worst consumer units I've ever used have to be ESR or LVE.
New posts
Reply to Fusebox consumers units in the UK Electrical Forum area at ElectriciansForums.net
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
I've been installing Type 2 SPDs in consumer units for several years now, and they always come as a pair, connected across L & E, and across N &...
I have a fuseboard change I need to do soon I’m putting in a FUSEBOX 7 or 10 way RCBO+ SPD My only concern is how I should run the pyro cables in...
I'm replacing my consumer unit (well, adding a second one, rewiring the house one circuit at a time, then removing the original one when it's all...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
