Discuss Garage power (high load) in the UK Electrical Forum area at ElectriciansForums.net
Kyran
Hi All
Any other thoughts, ideas/whys of legally doing it. I have client that wants to rewire his large/double garage as he wants to put his kilm and potters wheel in it plus run whats there and power for a new electric garage door (13a plugged one). currently theres lights, fridge/freezer power down to green house running heater.
So he want to power
kilm 3kw
potters wheel 400w
minimim heater 1 kw for him self
fridge/freezer
lights
garage door
green house heater.
He currently has a 2.5 t&E fuse down off his living room ring.
What i have quote to run a 6mm from a new supply (split tails) due to old board that is currently there. Garage CU in the garage that would run 6 10w led floods, 6 sockets around different parts of the garage, three circuits. intergreat the green house power in to new board. all cabling in conduct. The garage is 7m by 5.3m wide the 6mm armoured is about 20m long.
He does not want to pay to do and want to to requite to take the power off the ring, which i have said its to much and he would end up running out of power as the kiln takes to 3kw and even if you just have the kiln and fridge it will blow.
Any other ideas.
he's a muppet . your plan looks sensible, as long as the calcs. work out OK. split tails and fit a 40A KMF to supply the 6mm.
Thats what i thought, and thats what i was doing to do. to run the 6mm i would have to crule around under the house and install the new board as the intake in in the centre of the house. and has a coulpe of old boards of it so a new one would be the only choice. i was going to put the kilm on its ring/differnt to the fridge green house heater and garage door any way
another point to bear in mind is that if you split tails, you need to fit a D/P isolator between the meter and the henleys, in order to provide a single point of isolation for the whole installation.
NO. single point of isolation, whatever the earthing system.
IEE Guidance Note 2 - "Isolation & Switching", p.40
"It is permitted for a dwelling to have more than one electrical installation. Therefore one 'main switch' is not required to isolate all consumer units simultaneously provided the consumer units have an integral main switch.
"This situation frequently occurs when an additional consumer unit is added, e.g. to supply an electric shower. Regulation 537.2.2.6 requires each device used for isolation to be clearly identified by positional or durable marking to indicate the installation it isolates."
i stand corrected. it's what i was told many years ago and have not questioned it.
Reply to Garage power (high load) in the UK Electrical Forum area at ElectriciansForums.net
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
Hi, I’m new to the forum and am seeking some advice please. I’ve picked up a job that another electrician has abandoned, the job is to...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
I thought I would take a few minutes to give my recent experience in wiring a large garage for power and an alarm circuit. This relates to clipped...
