Jesus they are over £600 each
£6000 on lights, plus fitting
i can guess the answer
Where did you get £600 each from?
I can get that particular model for £180 - £230 dependent on bezel plus Vat.
You need to shop around and don't take the word of the 'B&Q' sales banter.
Having said that, Ground lights are always susceptible to ingress of moisture and filling them full of gunk just delays the time when they have to be maintained. and rather than drying them out you then need to rip them out and replace.
I have to maintain a whole collection of buried lights and even the most expensive at £750 per pop will eventually allow a small amount of moisture in, albeit 5 years.
Explain to the client that no matter how much repair work you do they will need continual maintenance....
I didn't run down to b&q for a price mate lol
I googled the product code and opened about 5 links and they all over £600.
£150 isn't much better to be honest
It's still a massive amount for some some feature lights
Yep, I agree. Its an expensive outlay for anyone to contemplate. So any prospective client who is struggling to get the price down is likely to want their extra pound of flesh when it comes to changing a lamp or fixing minor problems. These clients will always believe that you are at fault and resent the outlay.
When I get this type of prospective client I usually point them to the light fittings of their choice and let them do the purchase. They can then be left to contemplate the labour costs and get quotes to install.
I would fill the bottoms with magic gel up to the base of the lamp holders, then put some silica moisture eating tabs in them or a small bag of rice and do all this on a sunny day in the summer when there is less moisture in the air. I find most water in walk over lights is probably due to it getting in during the installation usually when the bloody customer wants the work during the winter so they can use them in the summer :(. Also if ever installing walk over lights from new and if they except stuffing glands wiska do special versions with a gortex one way valve that let's the moisture out whilst still maintaining IP68.
Goretex valve? Gosh, that's clever!!
Fill them up with clear silicone sealant, then nothing should be able to get in, then you can have fun pulling it out again when you have to change the lamp-bulb!
thanks
This is along the lines of what I was thinking. Hadn't thought of silica bags good idea! Also the glands will investigate
