Jesus they are over £600 each
£6000 on lights, plus fitting
i can guess the answer
Where did you get £600 each from?
I can get that particular model for £180 - £230 dependent on bezel plus Vat.
You need to shop around and don't take the word of the 'B&Q' sales banter.
Having said that, Ground lights are always susceptible to ingress of moisture and filling them full of gunk just delays the time when they have to be maintained. and rather than drying them out you then need to rip them out and replace.
I have to maintain a whole collection of buried lights and even the most expensive at £750 per pop will eventually allow a small amount of moisture in, albeit 5 years.
Explain to the client that no matter how much repair work you do they will need continual maintenance....
. Also if ever installing walk over lights from new and if they except stuffing glands wiska do special versions with a gortex one way valve that let's the moisture out whilst still maintaining IP68.
