Search the forum,
Discuss generator switch over in the UK Electrical Forum area at ElectriciansForums.net
T
tbs1983
I've got a customer who lives in a rural area and would like to install a back up generator in case of power failure, he would like me to install some form of switchgear to change from mains to generator as and when required. In principle the idea is straightforwards but wondering if anyone has done a similar scheme and how they went about it. my 2 main concerns are finding a way so that only 1 method can possibly be active at once (e.g. I dont want the generator running during a power cut and then power comes back on), and secondly how do I prevent the generator from backfeeding into the main grid. i suspect there may be some kind of changeover switch on the market, anyone come across one?
Thanks in advance
Change over switches here:
32A & 63A 3 Pole Change Over Switch
You need to think very carefully about earthing and fault protection when running on the generator. Also, the gen needs to provide a sufficiently smooth output for whatever loads are to be supplied. A good quality one with the output provided by a true sinewave inverter is probably the sort of thing you should be looking for.
I stand to be corrected here ,but don't forget that you are installing that change over switch in line with your incoming supply , so it will need to be sized to them and not just the generator supply .
Without some real information I’m not helping you kill innocent DNO workers.
Fairly straight forward? I don’t quite think so.
People supplying generators specifically for this purpose and will have the generator switch over panel for you panels look fairly simple ... As there a purpose built unit I would youse one every time
Reply to generator switch over in the UK Electrical Forum area at ElectriciansForums.net
hello guys, hope you’re all well. We are looking at installing the Hager SFT240 changeover switch to three live aboard boats with an electric...
Good day all, I'm writing from the Commonwealth of Dominica (NOT Dominican Republic) where we have single phase 230V, 50Hz. I'm managing a...
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
Just a query. As people have been asking me about changeover switches and generators. If a domestic house already has PV solar, and customer...
