W
wolfiehogan
Hi guys, just wondering how do you connect up a consumer unit to have all the circuits working on the mains but only essential circuits to work on the generator without having feed back. Cheers
Don't know a great deal about the installation of alternative sources, but first of all I'd have the essential supplies on a dedicated consumers unit.
Eng54 is the man to speak to, are you looking to install a change-over switch of some sort/UPS during the change-over, you will need to be aware of the earthing arrangements.
Yeah I was going to address the earthing in another topic mate. Just wondering how can I have all circuits running through the Mains but only essentials on the Jenny
From what you have described I would be possibly looking at installing 2 boards, 1 non-essential the other essential, have a change-over switch on the essential supply linked into the generator/mains. Depends on how essential the supplies are to how you carry out the change-over.
No - your only supplying the essential board via the generator and change-over switch, non-essential board is straight off the mains.
Sorry prob annoying you at this stage but I need the two working off the Mains but only one when the Jenny kicks in
Let me try and explain again, 2 x Boards (Non-Ess & Ess) Non-Ess connects to the mains, Ess connects to a change-over switch, from the C/O switch 1 side connects to the mains and the other side to the generator. When the mains drops out the Non-Ess board is dead, you operate the C/O switch and start the generator or if its an auto it will all do itself and the Ess now has power. Hope that is a little clearer :)
Yeah have it now I was positioning the c/o switch in the wrong place. Cheers for the patience lol. Now for the earthing lol
What sort on generator are you thinking of using. If it’s a smallish site generator then you are liable to run it to trouble with them being centre tapped to the frame.
And that was the end of that, I think you scared him off :)
As I mentioned earlier not had experience with alternative sources, but I take it that the generator supply would then be connected via a TT earthing system directly connected to the frame?
