stigwart
He might even mean genitalia? How do you you turn em on!!
You can make of it what you will. Trying to make many site generators TT end tapped will result in half the winding being shorted out.
An over sized generator working light with soot up and wreck
That's constructive, thanks...
I’m not doing a lesson in engine technology! I’ll add I’ve was phoned last night about an engine (petrol) that just isn’t running right. It just needs a de-coke. It’s pinking (pre ignition) due to carbon build up. It’s a big engine just pootling around town, the best cure for it would be a good long fast run.
With diesel engines it can be catastrophic. Wrecked heads, turbo’s, injectors and the best bit if the carbon gets in to the sump, the crank shaft and big ends are shot! Doesn’t do the liners and rings any good either.
An engine has to have a reasonable loading to keep it in good form. “It clears the tubes” as Grandma would say while holding you’re head over a bowl of VIC’s.
hi guys has any off yous got any good links to information so i could learn more about setting up generators safely, and i could come back with information on how i plan to do an installation. as i have said before i am not actually installing this it is only so i can improve my own knowledge. i did have a crappy apprenticeship so thats why im on a site like this to learn from experiences people like yous.
