Discuss Getting my head round earthing! in the Australia area at ElectriciansForums.net
Y
YTSOxford
I know that its prefered to place an outbuilding on its own earth rod to prevent faults traveling back to the house, so the way I usually do it is run 2 core swa to the second board, and terminate earth at the supply end.
I use metal boards because the smaller plastic ones are a right pain to get on with the amoured cable, but surely the metal enclosure which is earthed would connect to the earth in the armour... connecting the earths again????
If you wanted toTT it AND use a metal CU you would need to provide an insulator between your gland and the board eg plastic conduit adaptors or fit a one gang plastic box c/w blank plate.You would also have to ensure that the brass gland is fully shrouded so as the two earthing systems cannot be simultaneously touched.
I'm also not sure about your origional statement about earth faults travelling back to the house.Its often done if there is exposed metalwork or pipework to save having to run 10mm bonds back to the main house.
Reply to Getting my head round earthing! in the Australia area at ElectriciansForums.net
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
5K
