I'm having an issue at home that I don't quite understand. It's been happening since I bought the house about 16 years ago.
I have a GFCI receptacle in my kitchen, above the counter. Nothing is plugged in to that outlet, but it appears to be ran in parallel to another receptacle above the counter (that has a can opener and a water dispenser plugged in 24/7), and an outdoor receptacle that's about 1' above the deck floor but under the eave, and it has a waterproof cover.
When there's a storm in the area, every once in awhile there will be a big crack of thunder, a flash of lightning, then POW!! The GFCI flips off.
Since I can't duplicate the issue on demand, this has been tough to figure out. I don't see any way for water to be getting in the receptacle outside, but the fact that it only flips when there's hard lightning (even when it's not really raining) makes me think that maybe it's a power surge instead of water? Unless maybe there's high humidity, and the lightning is charging the humidity enough to trigger the GFCI?
What do you guys and gals think?
