Discuss Glass Top Stove Inside a Drawer? in the UK Electrical Forum area at ElectriciansForums.net
It would be possible.
If it were my house, I would want a control system that prevented the draw from being closed when stove is still hot and prevents operation of stove unless draw is fully extended and locked.
Thank you!
You mean like some kind of carpentry solution that locks into place and/or covers the controls until fully open, correct?
Thank you!
More like a sensor and relay/contractor I would have thought.
Anything is possible, usually.
But not in this case, if the idea is to have the hob moving out from under the worktop on a drawer mechanism.
There are too many issues.
First one being as per James, it needs to be electrically isolated untill the hob is fully exposed.
The hob needs to be well supported allowing for the weight of pans on it, a sliding drawer won't be able to do that.
When pulled out it needs to be perfectly level otherwise the pans may slide.
The cable connecting it will have to be flexible and suitably rated.
The list probably goes on.
I doubt you'll find a professional prepared to connect it up.
I understand, ok, thank you
[automerge]1593082518[/automerge]
Understood. Thank you!
my question would be why would you want to do it?
I think it's to save time in the morning... you can cook your egg and bacon on the top drawer, while putting on your undercrackers and socks from the drawer underneath... then grab a shirt from the wardrobe next to it... makes perfect sense to me.
Many caravans have a hinged worktop that comes down over the top of the gas rings.
I expect that is what was being suggested
and there's nosafety devices to stop the flap being put down when the rings are lit. only a numpty would do this.
Mine has a notice on to that tells you not to put down when rings are hot.
Never checked if there is an interlock to prevent stupidity.
VW Californias don't have the interlock... and they are all factory fitted and very high quality spec... like £70k new for a transporter ?
worlds gon mad. Mrs bought Fairy pods for washing. childproof catches. need a hacksaw to get in them. and warning to keepout of reach of childtren. how in hell can you get yor child to do the washing when he/she can't get at the soap?
Reply to Glass Top Stove Inside a Drawer? in the UK Electrical Forum area at ElectriciansForums.net
I have a rocker type light switch the sticks out bit too far and interferes with a drawer, as in the picture. The switch seems properly installed...
Quite a few new builds are popping up locally in my area. I have noticed that they are not even being first fixed until the buildings are...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
Hi all, Thanks for checking out my thread. The tenant renting my apartment has complained about high electricity usage. I offered we add a timer...
