Discuss Good cable to use outside in the UK Electrical Forum area at ElectriciansForums.net
hello guys
I have a lighting install at high level outside a house.
I don’t need additional mechanical protection and would like to use a good UV resistant insulated and sheathed cable.
Don’t want to use conduit as it looks ugly.
I normally used white FP 200 which the manufacturers said supports UV light exposure however I have seen a few installs where after 6 years turns to dust.
(I might be getting a phone in from client is a few years time as a result)
Nearly all black cable has good uv resistance.
The black is normally created with carbon dust in pellet form as the material is being processed.
Obviously check with the cable spec but black anything is nearly always considerably better uv resistance than the same white cable.
I tend to use standard black flex for domestic lighting circuits outside if the installation method allows it.
hello guys
Don't forget you'll need to secure it with fire resistant fixings at intervals
I tend to use H07RN-F. It's tougher & thicker than the normal black rubber cable H05. It's rarely on the shelf, normally have to mail order it.
hello guys
I use black rubber flex. I would usually use H07RN but on occasion would use H05RR. I personally think that even black PVC flex (H05VV) would be ok outside as I put some in my own property many years ago and it is fine. However I use rubber for customers as that is the correct choice. Also, this is only if it does not need mechanical protection, otherwise SWA.
Manufacturers instructions often say to use 1mm H05RN but finding that is like gold dust, so you have to bump it up to the H07RN. You do find that because it is rated up to 700V it is quite thick which can be a bit of a pain sometimes.
This is just one of many useful threads on outdoor cable..
Outdoor Flex Cable RR-F or RN-F - https://www.electriciansforums.co.uk/threads/outdoor-flex-cable-rr-f-or-rn-f.169160/page-2#post-1463746
Reply to Good cable to use outside in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, I don’t really know where to post this, sorry if it’s in the wrong place. After posting a thread about old lead sheathed cable in my...
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
Hi , Wondered if anyone can help , i currently install and test Trace Heating Cable on Mechanical Pipework for Frost protection . Recently our...
Hi, folks.' I have a carrier 38MGRQ48E '5 zone' mini split system with 4 'heads'/evaporators installed, and one 'channel' still open. Had it...
Getting desperate to clear my small garage, and I have a bit of old red/black T&E. I used a few bits to add a socket or two in my flat and a...
