Discuss GRID switches. GRRRRR.! in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
Hate the bloody things. 4 D/P 20A switches with 4 fuses, During a current job, UFH, some mods to sockets and switches, maybe due to dust from retiling, 1 switch started arcing. linked out till new switch came. fitted new switch with much cursing, terminals too small and not deep enough, ragging the whole issue up, down, sideways to connect, finally got the whole lot back together only to find that another switch had given up. O/C on both poles. had to pull the lot out again, link it out, order new switches. luckily customer gave me a beer before I got the hammer to it.
I feel you!! Those terminals are a bit of a struggling with a few 2.5mm2 hanging out the back. Not really designed to be tightened too much!
You have my sympathies.
I had to change an 8 switch grid the other day and typically not enough slack to work on it nicely. Right pain in the posterior, could quite happily have kicked the --- of the body that installed it.
and that was just after fighting with a 2 gang dimmer on a single 25mm back box with 3 3 core/e and 2 T/E connected, all in 1.5mm and Ns in a chock blok.
why can somebody design such an abortion whereby the exposed stripped copper can't be more than 6mm or you get visible conductor at the terminals? any terminal taking 2.5mm should be deep enough to accept at least 12mm.
Another case of modern day accessories not being suitable for purpose. Thirty years ago when todays wiring methods were not employed they would have coped effortlessly.
and regardin previous post about the bloody double dimmer. 3 x 1.5 into 1 terminal, FFS.
Best to use a 47mm deep k.o. box. I was wondering if doing the links with stranded conduit singles may help? What make was the grid switch Tel?
no chance for deeper box, steel RSJ behind. and the grid switch is Tenby.
Ok for lights, a nightmare for appliances ....
Never suggest them and point out their shortfalls to clients.
Don't like fixing them!
I sympathise with Tel,as a great deal of these layouts,are designed in kitchen sales lounges,over a coffee,with little regard for the installation issues and longevity.
The last one i dealt with,had 12 switches,and would have looked good on the set of Startrek...but otherwise,not necessary.
I carved out further back-space,terminated all the t&e to a DIN rail,and wired the rest in flexibles,a la panel spec,loomed with a pull out curl,and face hanger cables.
Lots of work,very expensive,and do i think the householder knocks them off every night? ... Nope :)
I fit 4 gang grids all the time for house builders.
Thing is they look much better than having 4 x fused spurs above the worktop and no they do not accept sockets mounted in the units.
I use a 47mm double back box, they aren’t fitted with fuse carriers which is pointless, and I chop the box back an extra 10mm.
A little further back if 4 mm is required for the circuit.
Agree they certainly make you mad,I find all Mk grid switches are poor,terminals are rubbish,frightening pushing all back wondering if you’ve caught a cable...& if you replace a switch it’s a nightmare.
The Mk ones they can be pulled out,but make sure the supply is off.....Bang.
Reply to GRID switches. GRRRRR.! in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm new here so apologies if this isn't the correct area to post this. We moved in to a bungalow around 8 months ago and had a full re-wire...
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
Hi there. Recently our bathroom extractor fan broke, so I got a new one but I'm having difficulty wiring it (homeowner DIY guy here). So... there...
Hello. I'm in the UK, and have some questions/concerns about my kitchen set up. So the fuse box has 4 breakers/circuits for the kitchen (the...
