Discuss has your sky gone fuzzy in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
in the norfolk area (others may be the same) this week as part of the digi switch over they have moved some channels and turned up the power
the result of this is that as standard the sky rf2 outlet is fed on ch 68 and something is now interfearing with all tvs fed via rf2
its a simple fix though
press services on sky remote then if hd 001 select then goto rf menu and overtype 68 with a different channel (i used 33) then save settings
then auto tune tvs fed off rf2 (not main set as fed off hdmi/scart)
if not hd its the same but services 401 select
Reply to has your sky gone fuzzy in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
"Hello All", I have a problem with bad interference on the reception of my Home`s TV`s that are connected to Sky Digiboxes in other rooms via...
24K
