I have absolutely zero experience with MVHR.
The issue I have in my own home is as follows.
Log fired burner in kitchen supplies hot water and heating via a thermal bank / store. Approx 2kw to the room and 9kw to the water.
If we want the heating on then this is on, combined with all the other usual heat generating guff in the kitchen, the kitchen overheats before the rest of the house heats up, opening the kitchen door doesn't cut it.
I would like to be able to shift some of this heat elsewhere, most likely the downstairs hallway.
Is MVHR a sensible option or would I be better off just using a thermostatically controlled fan to move air via insulated ducting from one room to another?
