Discuss Help Bathroom light won't work in the UK Electrical Forum area at ElectriciansForums.net
Andygtv
Hi this is confusing me I am not sure what the 2 black wires should be doing
My light won't connnect
Many thanks
The two loose blacks are likely neutrals and belong with the two blues in the connector.
The black with red tape is the switch wire.
Switchwire to L of your fitting, blacks and blues to N and of course green/yellow to E
Ideally, and more importantly, safer is that all that be put in a joint box above the ceiling (attic above?) and just have a L,N and E coming down through ceiling to fitting.
Important warning:
The reds and browns all tied together there is a permanent live. Isolate the circuit before working on it.
Reply to Help Bathroom light won't work in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hi, I'm replacing a light fitting in the bathroom but the wiring is confusing me, black brown and grey? Is black neutral and brown live in this...
I have 16 ceiling spots to be replaced in a room being repurposed as a bathroom. Some will be over a shower, basin and bath hence need to be IP65...
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
