Discuss Help needed - overhead wiring in the Industrial Electricians' Talk area at ElectriciansForums.net
T
tronic
Hi all,
I am new to all this forum stuff, so apologies if this is in the wrong place.
I am doing a rewire and need to get to an outbuilding. The easiest way is to use a cetenary wire (concrete everywhere). I am going to use arctic flex but notice the regs say that PVC must be protected in direct sunlight, how can I achieve this??
Aaron
Reply to Help needed - overhead wiring in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi All, I am looking to install a Quinetic double gang in line receiver switch (QURS2W) in my hallway on the ground floor to control the lights...
Hello, I am an enthusiast amateur undertaking wiring of two outbuilding under a building notice. I am soon to be subject to a first fix inspection...
Reaching out for some help/guidance and sanity check. Apologies in advance for the long post, but wanted to make sure it was clear. Thanks in...
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
