FFFPatriot
- Reaction score
- 1
Greetings all. I have a trailer that I built that is framed like a house. What I want to do is have an rv like cord that I can unplug/ plug when I take it on the road. I have 2-2-2-4 aluminum wire that is ran underground that goes to a 100 amp breaker panel in my garage. The other end comes up from the ground next to the trailer. Inside the trailer, I have four 15 amp outlets that will be on it's own 15 amp breakers, and one 15 amp breaker for two small led shop lights. I have a 70 amp breaker panel ( not yet installed ) for the outlets and lights. What do I need to do to make the connection between the 70 amp panel and the 2-2-2-4 wire outside? I want to be able to have some kind of heavy duty cord ( about 6' long) that I can plug/ unplug when I take off on the road. I don't need to have any power in the trailer when I take off from home. This is a small 6' x 12' trailer that I've built for a mini weld shop. My welder is a Hobart Handler 140 110v welder. I'll be building a down draft welding table with a fume extractor that is a 6" duct fan that goes through the front wall to the outside. The lights, welder, and fume extractor will be running at the same time, and each device are on their own 15 amp breaker. I've talked to the sparkys at Lowe's and Home Depot, and nobody had an answer to a solution for me. I thought of installing an outdoor 100 amp panel on a post outside and wiring in a 50- (70?) amp female ended rv cord off of the outdoor panel that would plug into a male ended rv cord that's wired into the breaker panel inside of the trailer. Any and all advice would be greatly appreciated. Thanks in advance.
