back in the early days of the 16th ( 90's), it was bandied about a lot. many sparks were told by more experienced guys that exporting PME was not allowed. probably those 15th edition sparks that wanted to use up all the gn/y they could find by bonding anything metal. i once worked at a site where 20 steel tables in the works kitchen were all bonded together.
In the 15th days , it was an explosion and everyone went mad with sup bonding and not wanting to export an earth some were saying you bond metal window frames , some saying no , some saying you have to bond metal waste pipes others saying no because of expiating an earth , on the DNO and even today they still don't want anyone exporting an earth on PME systems ,,,
Quote Ray
They certainly did Ray
The spec off a council here once stipulated unbroken 10mm bonding to the Bathroom (in addition to the main bonds)
The cable had to loop every piece of pipe in the bathroom,any and all colds/hots/wastes/rads ( notice the plurals)and whatever else may have resembled something metalic
The council tech guy must have done the full 6 day course to supplement the Bricklaying skills
There again,its what they were paying for and it was also what they got
there are a lot of assumptions in your first post sparksburnout
you own a copy of the regs . all the answers to your questions are in there ...
I am not quite sure what the purpose of your reply is Jack?? As you are no doubt aware it can be difficult for those of us less experienced than some on here to interpret the regs, that is why we ask questions or ask for confirmations. Are the assumptions I have made incorrect? I would welcome you advice and wisdom but if you can't/won't then that's up to you i guess?
