L
Lixy56
There I was, just cooking toast when out of nowhere the toaster popped and sparked. Now all of the eletricity in the house has gone out sans the lighting and I need a fix ASAP because my poor gecko will be getting cold! I'm not tech savy in the slightest, the most I think I managed to do was a reset that did nothing. I'll attach a picture of the mains box(?)
THANKS!
That's a fire alarm box not your main consumer unit.
  • Winner
Reactions: Pete999 and Markyd
Thats awkward ? but its beeping and three lights are lit tthat say
General fault
Battery fault and mains fault
Battery failure and charger fault
Does this help in anyway to know what the issue is? Where would I find the mains usually?
dont mess around...ring a local sparky
Do you know where your electricity meter is? Near it is normally a box with several switches on it.
THANKS!
Sounds like the RCD has Tripped locate the distribution board and re-set any switches that are down.... some types of RCD need to be re-set before they can be energised and this is one by pulling down the switch first then push it back up... before you do this unplug your toaster....... pictures are always alot of help?
Reactions: Lixy56
ok so the main switch to the right pull it down till it locks into place and then push it up firmly and it should lock into place then re-set the MCB which is the other one that is down and you shoul be back up and running
Reactions: Lixy56
Your socket breaker has tripped. Make sure the toaster is unplugged and turn the switch labelled 'sockets' back on. The RCD has also tripped but dabbers beat me to that!
Reactions: Lixy56 and Dabbers
You'ream absolute life saver! (Literally) Thank you and everyone else who commented for the help :) I'm assuming the toaster is bust and I daren't do anything with it now haha
Reactions: Dabbers and DPG
Yeah chuck the toaster. Not worth trying to save it. Have a sandwich.
Now that is sorted, are those RCBOs compatible with that board?
aren't eaton the new mem?
They are but I didn't think the new RCBOs fitted the memshield2 stuff? We still use the pods for those.
  • Agree
Reactions: James and 123
if you can fit it with a hammer, it's compatible. :) :) :)
Is the Gecko ok?
  • Friendly
Reactions: DPG and freddo
I expect he's fine, just disappointed because he likes toast. :)
Email
Time zone
Last seen
Help with mains ASAP
UK
Lixy56,
Timbo,
