Hi it’s the 3rd one from the left ithere all in the on positionWhere is the shower getting its power from? As far as I can see, all the breakers in that CU are in the 'off' position. Only the main switch appears to be 'on'.
Are they ? I wouldn’t know we purchased the house recently.How bizarre they are all upside down.
The writing on the mcbs is upside down.Are they ? I wouldn’t know we purchased the house recently.
Look at the name-test, and compare to the main switch!Are they ? I wouldn’t know we purchased the house recently.
They are I didn’t notice this before, any idea what the noise is? and what’s causing it?
'Connection seems hot' and 'wisps of smoke' also work well in my experience.I had an old style metre with the spinning wheel that made a loud squeak. Reported on line to SSE saying I was scared it might catch fire or explode. They came out and replaced very quickly. Obviously there are some key words to hit for a prompt response.![]()
Yes it’s coming from the meter only make the noise when the shower is running and that’s upstairs at the back off the houseAre you sure the noise is coming from the meter? Can't hear it very well on the clip, but it sounds like a shower pump on the other side of the wall.
sure it’s not the shower pump as you couldn’t hear it in the garage from where the shower is at the rear off the house but your welcome to call in if your passing and I’m more Staffordshire burntwoodI am going to put another vote in for a shower pump.
where in the West Midlands are you?
I may be able to pop in and clear this up for a beer if you are nearby.
How do you know if you're in the shower?Hi erm any ideas noises from the meter only when the electric shower is running
I was going to get onto that later. It's only a 32A MCB.. What rating is the shower? The impulse LED is flashing quite fast!
