This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
Dan Mabbott
hi am after some help with fitting a nest gen 3 to this boiler its a worcester danesmoor utility 15/19 oil boiler, this is the wiring behind the inbuilt programer. Thank you
Next??? Not sure where you got that. Am after help on where each wire goes from the nest heat link to the boiler control pcb thank you
we are not hear to give you step by step guide on doing the job .ring up nest .before you do any damage to the boiler and your self .
dumb ,think before press the button .
Thank you not thank you, got sorted by helpful guy who sent me a private message
