N
Nicholas69
Describe, for each of the following symptoms the most likely electrical fault.
A fault has occurred on a lighting circuit in the glass house area so that when it is switched on the RCBO protecting the circuit operates
the out side lights Obove the entrance only turn off when the protective device is turned off
