Discuss home easy in the UK Electrical Forum area at ElectriciansForums.net
We installed one for lake lights and fountains.
1.5 SWA to each of the 4 points, worked really well.
Only problems we encountered were,
Hand set went wrong a week after install. (Byron replaced F.O.C)
interferance from existing system in the house.(Door bell turned fountains on)
initial concerns about 13A max. (Not an issue when sums done!!)
We will definately use again as the after sales service was excellent, as was the ease of installation.
Have you used the sms sender before mate? they were about £80 when i first installed the sockets and lights at home a couple of years ago. I have sourced one for around £20 now so it well worth the money for when we are away for the fishtank lights etc
Yes I've installed a couple. My observations are:
1. The remote "steps" round each number in turn - i.e. you can go from 1 to 2 but not 2 to 1
2. The cable gland "holes" are huge and I couldn't locate a decent gland to use to give reasonable mechanical "strength"
3. You can't accomodate SWA
4. Once installed very easy to set up
5. Limited range
Yes on the range, I am sure I read that there was an 'add on' booster???? we were able to terminate SWA within the stupid supplied glands and the terminate the banjo ed earths into a terminal block....pigs ear but worked ok.
Did look at the SMS receiver, interesting toy!!!!!
Reply to home easy in the UK Electrical Forum area at ElectriciansForums.net
I will describe my problem in as much detail so you guys might be able to answer my question. I am never home, my Electric bill is $ 28 to $30 a...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
I am installing a ceiling fan in a newly built home. The builders have left the wiring for this purpose. In the electrical box on the ceiling I...
So as the title says, I have 3 panel heaters in my flat, but only one really needs the fine control i'm after, the other two rarely go on even in...
