Discuss Honneywell Thermostat showing low temp and Frost Mode in the Central Heating Systems area at ElectriciansForums.net
Hi
My thermostat usually shows a room temp of between 18 and 20 degrees
However occasionally it is displaying FROST MODE and showing low temperatures. Basically when it goes like this we can either have heating on or off with no control which is very annoying!
Can anyone advise, I have already looked up about frost mode but I do not know why this mode is happening and cant seem to remove it either.
Many Thanks
When some sensors fail they show zero degrees, in one factory I worked in the guy programming the machine was well aware of this, so wrote the program so if showing zero degrees it would lock out, however not really possible with a domestic thermostat as you may actually get zero degrees.
Most electronic thermostats have one of the standard sensors inside, not really user changed, it is simply a new thermostat job when they go.
Reply to Honneywell Thermostat showing low temp and Frost Mode in the Central Heating Systems area at ElectriciansForums.net
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
I'm in Raleigh, North Carolina and have a well for my house's water supply. For some reason, pitless adapters, which allow all piping to be run...
I recently fitted a Heatmiser Neostat for a customer in their hall- to control their radiators throughout the house (70’s 4 bed medium sized...
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
At our church, one of the things I've done is sort out the heating wiring (as best I can for now). The schematic is as shown below. The theory...
