Looking at some of the pics, crushed cables will cause problems with RCD's.
Although they dont look like they are on the outer sheath, when you open them up its plain to see.
This things usually dont rear their ugly heads until there is current flow.
I think I am just about done, so it's back on the phone to try and find an electrician in my area. I will try the links sent earlier in the post.
I will let everyone know once sorted out.
Thanks for all your help and advice.
Cliff
Hi,
just had a quick read of your post so correct me if I'm wrong. The fault is on the upstairs lighting.Is it all wired in a Jb or is it loop in loop out either way find which is the first point where the power comes in to the loft disconnect from here one side live rest of the circuit is dead see if it trips if it does not add next light on keep on add more lights back on to the circuit till you find it starts tripping again.
breaking the circuit down will get you near the fault.
Hi,
With respect, the OP in this is not an electrician. And talented as he may be, I'd be reluctant to advise him to do anything that might lead to that all too familiar tingling rising up his arm.
LOL yes i dont want that tingling up my arm.
Thats the reaon i bought the ammeter with plastic ends so i didnt want to touch metal to metal.
When the first electrician came around and started changing the You should see the wires in my loft wires around on the circuit board without turning it off I thought he was mad.
you should see the wires in my loft it's like spegatti junction.
I have found wire connected to live with nothing on the ends, old bakerlight light switches left live.
I know when to stop I think I need someone who knows what he is doing,
But thanks for all the advice.
Cliff
Best option there Cliff.
Looks to me like you may have a number of things that need sorting and its best left to a registered electrician to do that for you.
Good luck and let us know how it goes.
finally an Update for everyone,
I have now had an NIC electrician in today, he found what the fault was in 5 mins connected a big tester to the fuse board. Said it was a live to earth short or may have been earth to live if that is different. Then took 2 hours to track it down, unfortunately it was under our flat roof. the last hour was putting everything back together.
Let me explain when we moved in the previous owners had had the flat roof over our kids rooms made into an apex one. The flat roof remained but was now in the loft as part of the floor. This electrician has traced teh fault to 17 metres in from where he is unable to reach it. He suggested cutting holes in the flat roof but said the wiring is in such a state in the loft it really needs re wiring.
To help me he has re connected al lights apart from 3 where the fault is, all the lights in the annex he has rigged up a temp solution by connecting to a 3amp plug socket.
I have been charged £177.50 for today 3 hours work ( 2 people ) but if I take up the quote he will knock this off the price.
The price to re wire the upstairs lighting 7 lights + a fan in the bathroom. £920
make the annex on a seperate circuit and re terminate all lights in the annex + fit fan isolator in that bathroom. £280
add 2 rcbo's to board £60
He has said I need to upgrade the main bonding to gas and water fuse board £120
Test and provide certificates £60
Total £1440 + vat of £216
£1652 in all
Any advice is this about right are the things listed correct , i know it;s difficult to say without seeing the
house but any advice would be appreciated. I understand charges are different around the country.
With all the unconnected wires I found in the loft that were live and the peace of mind this will give us I
may have to do it.
Cliff
Sounds reasonable to me Cliff.
Just check the NICEIC website and make sure he is who he says he is.
