Discuss Hoping to get some help in the The Welcome Forum area at ElectriciansForums.net
ATJ1989
Hi all.
I'm looking for some advice on how to wire up a meanwell DRP-240-24.
I want to reduce the amount of power bricks and plugs used for my fish tank.
I have 8 plugs that I'd like to run off the MW PSU
The picture is how I understand it to work ? If someone could look at it and let me know if I'm right or not please
biggest wago is 5 port. but that looks OK as long as the MW supply is capable of handling the load, and all the loads are 24V DC.
Thank you, and yes the MW has enough power for all the equipment I want to run off it and they are all 24V I'll be doing another one for 12V at a later date.
Just wanted someone to confirm I had to right idea before I went ahead with it
So Ive got most the bits I need to do what I wanted. I was thinking of adding rocker switches to each of the DC jack plugs so I could turn them on/off individual without turning everything off at once. I'm told this could cause arching and would need to be addressed to safely add switches any advice on what to use?
A correctly rated switch should not cause any arcing problems.
Reply to Hoping to get some help in the The Welcome Forum area at ElectriciansForums.net
Hi - On our small vessel we have a 12v failry powerful motor to run the autopilot, where the power is supplied by the boat's battery bank. On an...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hello, I have a hypothetical question (I'm an electrical engineer) to better understand RCBOs and how they are used in the USA. Let's say I would...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
