Discuss Hotpoint WM52 motor in the Electrical Appliances Forum area at ElectriciansForums.net
handyman
Hi The connection socket on the back of a WM52 washer motor got damaged, so I obtained a new one. I proceeded to dismantle the motor but forgot to take note of which wire went where in the socket, what i can remember is that looking at the socket if you number the spade connectors from left to right, spade number 1 and 2 are most certainly the tacho connections from here on I don't know but I take it that connections 3 and 4 are the field coil connections and 5 and 6 are the brush connections, any help greatly appreciated
Thanks Ken
Reply to Hotpoint WM52 motor in the Electrical Appliances Forum area at ElectriciansForums.net
My beko will not run, it attempts to move in both directions with a belt or not fitted also shows no faults in checking with a meter across its...
i had a 3 speed blow motor to an AC fan coil unit. I disconnected the wiring and installed a new unit and forgot how the wiring goes, i no expert...
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
Iv been asked to wire a separator (portable to go to different farms and separate water from slurry) to a 3phase 40 kva generator. The separator...
