Discuss How common is reversed polarity? in the UK Electrical Forum area at ElectriciansForums.net
pc1966
Looking over the best practice guide to electrical inspection condition reporting the C1 "danger present" conditions are basically exposed live parts or reversed polarity. I guess the seriousness of reversed polarity is the lack of any meaningful over-current protection for faults to earth.
This forum's thread on dodgy pictures has several examples of exposed wires, etc, but how often have any of you seen a case of L & N swapped at the consumer unit?
It must be very rare to find reversed polarity at a CU. Whoever did it would have to be a special kind of stupid to get them mixed up.
although I have seen plenty of tails using the same colours and only a bit of red or black tape to distinguish which is which. Mistakes can happen.
I came across one once... I was convinced I must have made a mistake but no, it really was wrong and had been from new. It was about 10 years old.
and beware when fitting any schneider CU's. the terminals are back to front.
I installed a 12 circuit dimmer a couple of years ago which had the outgoing terminal strip labelled back to front. The terminals were labelled L1, N1, L2, N2 etc but they were connected the opposite way internally N1, L1, N2, L2 etc.
Obviously we found it when we started testing, and in this particular case it wouldn't have been too bad as, due to a suppliers error, we had the version with true double pole mcbs intended for the mainland European market. But a lot of these dimmers get installed without any testing and I dread to think how many of the single pole mcb version were fitted before we brought this to the attention of the manufacturer.
I saw it once. Guy came to fit new washing machine and fortunately used a socket tester. Raised the alarm when it yelled at him.
Tails wrong way round to main switch. Had been like that since a cowboy installed new cu. cannot have been even basically tested. it had been like that for a long time.
PC I’ve seen lamps with the polarity crossed and it makes the screw in base live and the tip is the neutral which makes the whole metal frame of the lamp energized
An interesting amount of feedback, I am surprised by some of it but at least it is good to see cases like that when they test, discover the mistake, and fix it before it is used for real!
Only seen it once after DNO did a meter change. Only identified by homeowner when the boiler started burning out PCBs
Reply to How common is reversed polarity? in the UK Electrical Forum area at ElectriciansForums.net
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hi all, Hoping for a little advice. I work in the Asbestos industry and we manufacture mobile decontamination units we follow the HSE 247 that...
Hi all, first post so go easy! This is for people who are looking for more info on the course and exams and is from my experience of doing the...
Electrical2Go - Electric Car Charging at Home - Comprehensive Guide As EV ownership and the transition towards electric cars rise, having a home...
A bit of a mini essay but these questions have been building up in my mind over the last weeks and months as I've been studying and volunteering...
